Clutch and flywheel question
Hi , I need to buy a new clutch kit and the dual mass flywheel is starting to chatter, Does anyone have any suggestion
on which to but . I dont need a all singing all dancing one, Somebody suggested converting to a solid flywheel
Any help would be great
Depends on what model you are driving. Either way the Sachs clutches seem to be quite popular on here.
If you are driving a vRS then for every day use the organic clutch would be the better option. :thumbup:
thats what i would like to know what solid flywheel can fit on these fabia vrs!
My cupra was very easy to do!
I've got one of the Jabbasport 6KG / Sachs sports clutches in my VRS! Its almost like driving the std car and is only a little more noisy at tickover than the std car. The clutch will chatter a little at tickover - just sounds like an older style diesel on tickover! I like it - Done almost 8000 miles since I fitted it and you will get no complaints from - other than it was over £900!
wot about the flywheel have u changed that?
