help needed with fabia tdi electrics
hi looking for some help
my dad has a 2003 Fabia 1.9tdi elegance
has been getting an occasional fault but is happening more and more now
while driving the following lights come on ABS,airbag,power steering
daslight go out, speedo stops working radio stops working, no power steering or starter motor
the fault will usually rectify itself after a short while all will go back to normal except the power steering, but this will rectify by stopping and restarting the engine
hoping for ideas before it packs up completely
thanks in advance
Check the battery connections and have the battery tested for a start.
thanks for the reply
have checked the battery connections
not sure it could be the battery as it allways starts 1st thing in the morning even with these really cold mornings.
reading the workshop manual all these seem to relate with the "electrical system control unit"
anyone know if these give any trouble or where its fitted so i can check the connections
thanks
Electrical system control unit is above the drivers side parcel shelf trim. Before you rip that out, check the link fuses on top of the battery for corrosion/bad connections. Also check the battery earth to inner wing.
