Superb II Green Line 1.9 TDI Gearbox problems
Hi I have this car for couple month, but little problem with the gearbox
The main thing is when I’m trying to put into 3 gear (Hard acceleration) its stuck before goes in? Need to repeat before turn on 3 gear?
My wife drive this car as well (maybe Im bad driver) but same problem.
Shi sometimes from second gear put in 1 gear, not by mistake but 3 gear in looks like does not want to go and when she repeating sometimes it goes into first gear
Im put the clutch again and then slowly put in to 3 gears. But it make crazy when I’m hard accelerating
It is feel that - when I’m trying to accelerate like 1 gear then 2 gear and 3 gear does not want to go in fast ?
Sometimes it is ok but feel hard in into 3 gear ?
If I’m changing gear slowly it is ok.- but where is the problem with fast change gears?
All Gear above 3 works in fast mode changing
My question1:
Did I bad driver
or maybe it is same on other Superb 1.9TDI
or need correction in gearbox?
My question2:
Local dealers where both fog lights need replacing due to drops of water. I did not see lot of water in my fog lights but when it is rainy day it is become inside fogy
So does it valid for warranty replace?
Thank you
it sounds like the gear linkages have gone out of adjustement, it should be an easy fix for a dealer.
