Flickering lights, dash board, interior lights and whining from front left of engine bay
my 01 1.4 mpi with 67k miles comfort has a relay annoying problem with the power flickering there is a wine in the frunt left of the engine bay as you look form the driver seat and all electrical systems seem to be effected buy the flickering head lights, inside lights, dash lights, door light and the wining form the behind the passenger headlight is in time with the flickering as well it seems to be getting worse
happens when siting still and some time at low revs it seems to effect the engines tick over in time with the flickering
some time there is none at all for 15 min and then it will come back on regardless of speed rev steering angel or road surface
i bought it only 2 days ago and am relay disappointed and relay want to try to put it right i live in Ireland and the cost of a new power steering unit form skoda is 800€ and the steering angel sensor is 80€
so id really like some advice on how to diagnose it fully as not to waste money on parts as im very broke
fi any one has a good resource to get cheaper parts than having to go to my main dealer would also be a great help
hi this is caused by the steering angle sensor being faulty usually, sometimes its the electric power steering unit that is faulty but you need to get it plugged into vagcom to check first.
Will the fault show up if it is either of those issues? as ive arranged to use the computer in the garage were i bought the car.
Is there any point in looking for a second hand sensor / pump if i end up needing one or is there any were to buy spurious parts at good prices on line
thanks for all your help this form is great
is there any other potential issues that would be worth testing for
Was it a private or trade sale?
I'd also be wondering about the condition of the alternator...
Steve
and battery ?
Double-posted thread merged with this one and duplicate post deleted.
Steve
it was a bought as seen form trade with engine and gear box cover only is there any good way to isolate the issue ie.
could i remove say the fuse or power cable to the power steering pump and see if the issue stops some thing like that and if so can the car be use with out it for some time if it stop the issue.
how can i test the batrey
how can i test the alternator
can i removed the steering angle sensor to see if it stop the flickering and if so is this easily accessible
find a good, local independant VAG garage, they should be able to all the tests required to isolate the fault
I got a 00816 fault stearg angle sensor fault any one got a guid to help me remove and replace this my self I have a drivers air bag so I'm a little nervus dismanteling d wheel set up some diagrams would help a lot
