Maxidot & Cruise thanks to Ben (aka Shark Performance)
Big thanks to Ben of Shark Performance PLC for fitting a new dash pod with Maxidot and Cruise control on my VRS
Well recommended if you are thinking of an upgrade, it certainly makes a difference to the inside of the car, the cruise is a must have.
Best part is you can use the MFD stalk to flick through tracks on the Columbus, it s not a MFSW but better than nothing.
Before and after pics included.
Also for sorting my ECU checksum problem, I don't fully understand the issue but it required a re flashed ECU at the main dealers to clear the warning lights. Luckily it was a recall.
Thanks Ady
What's the cost of adding maxidot?
I will let Ben answer that, I wouldn't like to quote his prices.
Excuse me for being a Female but what is Maxidot, I looked at the pictures but they seem the same. Thanks
Maxidot is fully functional MFD (Multi function display) which alllows full user information, the part comp shown in the second pic only allows limited information to be displayed.
Maxidot does have it's uses............ B)
Looks like a good result :)
I want one again now :'(
Ace - Shark's got public. B):smirk:
Yet another IPO opportunity missed.
Edited by wega3k
Ben is performing similar surgery on mine next Thursday (maxidot, already got factory fit CC on the Elegance) :)
The main reason for the change is not specifically to get the maxidot but to replace the instrument panel which has a number of inexplicable cracks in the perspex front panel just in front of the computer display and which spoils the otherwise pristine interior. Seemed silly not to do maxidot at the same time!
Knew I had a pic' somewhere...
Still can't work out who or what could have caused that...looks like it was attacked by a wild animal :S
it is no problem to change maxidot with VCDS... no problem at all...
What changed?
ALL IC or just the screen?
Thx!
Indeed you are right, as I use VCDS to perform the task emoticon-0148-yes.gif
What changed?
Thx!
The entire instrument cluster is replaced with a different one, it's the only way.
Ben - as well as a remap coming up, can you please PM me a price for the same work to replace the standard with maxidot please? 2008 vRS.
Ta,
Andy :)
Will do Andy :)
Hello i have 2 IC with maxi dot .I wont to instal them on a O2 1,9 tdi , I need anything else ?
One is from my car, I changed mine with one from VRS.
THX!
THX!
You need the SKC of each cluster and each car, and VCDS to program them in.
Well , my vag comander1.4 do not read the skc from my car...I guess I have that code from my key, is in a white plastic ....
That's what you get for using cloned tools and pirated software I'm afraid :)
k-can commander can read up to June 2006.....
My car is made in june 2005 and....i guess it is something wrong with k can comander.
I sow in it specifications Octavia 2 but....
PS can enyone tell my how can i have an avarat with custom photo?
Edited by gabi2004
How much does swapping these over cost? Also would I have to supply my own new dash panel?
If you'd like to drop me a PM with your requirements then I can give you a quote :)
Hello!
Can anyone give me a scheme or a diagram with pins from intrument cluster.
I wont to bring it to life on my desk and i do not know whitch pin have +, -, Can, L line, K line,power from lights etc...
Thx!
