Which rear brake pads do I need?
Depends if you have sensors on the rear or not.
No sensors! Just normal pads for 232mm discs.
I'm guessing I don't have sensors as the rear pads have started grinding(ooops) and there's no warning lights on the dash.
249's
Fabia's don't have wear sensors!
Fronts don't either so watch out for that. No huge biggie losing a bit of rear braking performance, but the fronts are a different matter. ;)
Thanks, fronts have loads of pad left so should be good for another while.
There's a really good chance the rear discs will be FUBAR'd too!
