ABS / ASR light on and codes stored for ABS fault in circuit + Relay for Supply Voltage Terminal 30
This is from a member's car I scanned this evening. His ABS / ASR lights are on. Anyone encountered this before? I've only seen 'ABS Wheel Speed Sensor 003 - Mechanical Failure' before, not 'ABS Wheel Speed Sensor 012 - Electrical Fault in Circuit'. Is it likely to be the ABS sensor itself / wiring / something else?
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HF HW: 028 101 229 2
Component: R4 2,0L EDC G000SG 7000
Revision: 12345678 Serial number: SKZ7Z0E2963103
Coding: 0000072
Shop #: WSC 73430 790 00000
1 Fault Found:
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: -98.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
The wiki says what you'd expect...
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor
ABS Wheel Speed Sensor faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor
Check ABS Wheel Speed Sensor
What I'm not clear on though is the relationship between the ABS 'Electrical Fault in Circuit' code and the Supply Voltage Terminal 30 codes. :wonder:
The electrics are designed to have a 12V supply, this at some point has dropped to 11.17V, which has caused the control units to log it. The word intermittent, tells me that this happened maybe just once. As a rule I tend to discount intermittent codes on the first scan, unless they crop up again after erasing and re-scanning. The data also tells you that the engine was not running at the time.
Your best course of action would be to check the wiring from the ABS sensor for any obvious signs of damage, if that checks out OK, connect a multi meter across the sensor terminals and take a resistance measurement or see if it produces a voltage when the wheel/hub is spun. I think that you have a faulty ABS sensor.
as per the previous post.
it looks like you only have an abs sensor issue, the other two could have been caused by the owner sitting in the car listening to the radio and so on without the engine running causing the battery voltage to drop significantly.
  • 3 years later...
I am having the same problem in my yeti where both ABS and TCS lights are on. I also noticed that i get 3 long beeps while ignition after this issue happened, but that was intermittent.
I am from india and my car is just 7 months old and is under warranty. Right now the car is with service center from last one week. All i know it's G45 RHS sensor issue.
- The wheel speed sensor is already replaced.
- They checked the wiring and all fuse.
- They even replaced the wheel hub just to see if it's an issue with sensor ring.
However the issue still persist. What could be the real issue. can it be ABS unit at fault?
I am experiencing this atm and although my fault is reading on vcds as osf abs sensor I have replaced the abs sensors and hubs both sides (just for piece of mind) . Reset the faults yet it still persists and still no speedo reading and still abs/asr warning lights.
I'm now in the process of wiring tracing.
I have seen somewhere on here whilst Google searching that someone found dirt in a joint in the loom and that had worn through causing wires to make contact. I willtrace it and let you know my findings.
Oh I should point out I have checked the resistance on both sensors just to make sure they are both fine and they are.
