retro fit cruise control Octavia II
Hi looking to retro fit cruise control to my recently purchased octavia II VRS . I hav access to a diagnostic computer that can activate cruise control. Im picking the stalk up this weekend. Is there a step by step guide anywhere? Ive had a quick search but nothing come up. Thanks
Bob
  • Replies 89
  • Views 38.1k
  • Two little tabs on the top left and right rear, on my 2006 I had to remove the steering controller first which is the very bottom square as the electrical connector from the slip ring goes into it. Th
  • INCARTECH = COWBOYS!!! cant be done on your age car, what a load of ****
  • Thats not base spec! Mine never had anything, no central locking no rear armrest no fuel computer a key locking fuel cap etc etc. If you want to just fit cruise control then a midline controller and s
Just done mine last week so easy....
1) find out which steering wheel controler youve got as certain ones need to be changed.
2) disconect battery ( a must!!)
3) remove airbag by inserting small screwdriver in slot at rear of steering wheel (use mirror to find clip)
4) remove steering wheel(M12 spline drive bit req)
5)remove steering wheel adjust handle and sliver screwfrom underneath cowling
6)remove cowling halves
7)remove steering controler(box at bottom)
8)remove slip ring(DO NOT TURN IT)
9)remove esp magnet
10)remove stalk
11) replace with new stalk
12)replace the stuff you took off
13)recode engine and steering controlers
14)road test
Hope this helps
PM me if stuck.
Trev
Thanks for the reply. How do I tell what steering controller I have will vagcom tell me, and when I find out what one I have how do I find out if its compatitble ?
Yes vdcs or vagcom will tell you, if your getting the cruise kit you will have all the part numbers in the instructions.
Trev
Ps Pm me if you get stuck
i retro fitted mine.
everything went in straight forward but the vag com wouldnt work so had to take it to skoda they charged me £37 to activate it.
i did recieve a step by step guide from a guy on here with pictures and everything but i cant find it.
he might spot this and try yo help
I have VDCS and mine worked first time,I know upto 5/2005 requires the wire after 5/2005 does not instructions are misleading had to work it out from the german instructions!!!!
Trev
Ok does anyone know what I need to go into and change in vagcom after I have fitted the stalk ?
Did you manage to fit ok as I have the pdf with the install guide.
nah not fitted it yet mate, the PDF would come in handy, thanks!
Pm me your email address and I'll send it over.
Thanks for the PDF, exactly what I need ! :thumbup:
  • 4 months later...
Can i have a copy please??
this is my next job
pm me your email and I'll forward it on.
Excellent, just the thread I was hoping for! I am doing this as well within the next 2 weeks. :D
I have PM'd you vRSMart, thank you in advance! :)
Where did everyone get the cruise control stork from?
edit: vRSMart - I think your inbox is full! ;)
Edited by Guest
yes it is...i've tied to pm you twice
get cruise control stick off ebay seller 'vwteesside' for £75 with instructions
i have not ordered yet.
Edited by sprout99
Thanks sprout, I don't spose you have a parts number do you?
Just seen this, my inbox should soon be free, I've just put another yrs subscription on :thumbup:
Can someone just confirm the part? I have bought a cruise control stalk & instructions second hand, and whilst the part number 1k0 is correct, the picture of it doesn't look like those shown from the VWteeside images. The seller also doesn't mention a wiring loom either? Whilst waiting for the seller to confirm, does this sound like it is going to cause me issues? :(
all fitted and working
hardest bit was getting at clips hidden in middle of delicate electronics
  • 4 months later...
I would like that pdf as well!
I own a 2009 octavia stationwagon TDI 1.9. Bought a stalk from a similiar model & year from the scrapyard. Installation was easy & I have recoded the module itself (0000034 instead of 0000004) and enabled the GRU login code 11463 - which was accepted by the ecu just fine!. .
I can validate that the buttons on the stalk works by monitoring with vcds. What other steps are required?
Please do send me a pdf of this - or maybe we should post the stuff here!
  • 4 weeks later...
The stalk worked, it was me not testing it properly.
I took some pictures during the operation. Both the stalk-change and the vcds.
http://www.inorp.com/blog/2011/01/12/skoda-octavia-2009-aftermarket-cruise-control-replace-stalk-recode/
Hey ,
Can anyone please confirm that no extra wiring is required to retro fit cruise control on an octavia II 1Z.
Edited by pz1811
  • 2 years later...
Dreging this up.
Had a very strange quote from Incartec York.
Thought i'd check here for advice.
I have a 2008 CR Octavia. Its has the half size multi function display.
Is it possible to fit cruise and what would be a reasonable cost for fitting. Incartec wanted £500+ for some aftermarket bodge. I said about just changing stalk etc but they said it wasn't possible on this age model.
Should be very possible to install as factory with a stalk.
They're talking out their arses.
OnlyChargedDubs isn't too far from you - Matt charged me less than £100 for a new stalk and programming it all in. I don't have access to VCDS etc so for it all supplied and fitted I didn't think that was bad when Awesome etc charge a load more than that.
