Dashboard Lights
Hi All,
It seems as allways the Briskoda is again the fountain of all knowledge when things go wrong. After buying a new car the Skoda was left to the road side for some time while i enjoyed the fun of the new. On comming back to the car i found the battery was dead, almost turned a few times but then only clicking.
I decided then that the booster pack may have had enough charge in it to help turn the car over only to be dissapointed.....
On buying a charger the Battery got upto approx 75% of what the charger was saying Full and back out io went to the Car and Yippie it started first time. On finding this i left the car with the thought it was only a dead battery and the issue had been resolved.
Today i decided to resorect the Skoda to reduce the annual miles on the new car and it is more fun than the Metro (wifes car). I received a few bings and warning lights today.
Skoda Octavia TDI 2ltr (2007)
Steering wheel (yellow)
Engin management (yellow)
ABS (Yellow)
Park light (flashing Red)
On the quick 30 min drive i thought might top the batter up and resolve the issue i noticed that the Speedo was not working either. Noting that the car is still within warrenty i decided to call Skoda Direct to have an engineer look at it before the end of the warrenty. The RAC man arrived tutted a few times and began looking around. He checked Fuses and reset the onboard battery by clamping the + & - together then ran a few tests on his tough book. i noticed some communication errors with his machine and the code P0600 that on searching has only shown up negative control module errors.....
Now the car Starts > Stops > Turns and accelerates without issue.
Is this going to brake the bank to resolve ?? i did notice the tech support guy laughing on the phone with the RAC guy about killing the car...
Any Ideas?
Thanks in advance...
Bad_Shot
The Dashboard lights/speedo not working combo has been reported on this forum as pointing to 2 faults.
The first is the ABS Module and the second is a duff battery, fingers crossed its the latter, its several hundred quid cheaper.
Thanks for the responce, sorry it took so long but i lost the post on the forum ;). It is going into the dealer today (Still under Warrenty) so its nice to know what might be going on :)
Cheers,
Just dont want the £1800 bill ive seen here.......
Edited by Bad_Shot
Cheers,
Surely if it's under warranty you should be home free :D
You really need to have the faults read and probably a few things reset. Control modules don't often lose their coding but starting with a jump pack can spike things, it has been known.
Where are you located?
Im Down in Essex going to the Chelmsford dealer
3 hours From you...... I Wouldnt be against driving up to you if it all goes wrong as i have family in West Yorkshire i could visit
Just Been to the Garage and come back with a huge smile on my Face
He has told me it is the ABS module and he will try to get one on a next day delivery and have it installed Friday/Monday all under Warrenty (6 weeks left on it)
Excelent Service from the guys at Preston Garages, Chelmsford.... 2nd time i have used them and both times good service.
The question now is do i extend the warrenty on the car once the 3 years is up?
