New Fabia owner, PAS not working, fault codes to read :D
Hey guys,
I bought a fabia that had had a front end ding, the bumper had been off, and I think a monkey put it back on as neither fog lights work (suggest not connected) and PAS not working so:
Basically a bloke on here (Ian - awesome guy!) checked out my fault codes as my power steering isnt working (light on while on ignition and on while driving, steering always heavy (no whine))
And this was the "list"..
Friday,12,March,2010,19:29:09:57524
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
TMBNS46Y023329478 SKZ7Z0A1027515
3 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-00 - -
17671 - PD Unit Injector: Cylinder 2 (N241): Implausible Signal
P1263 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00188
Shop #: WSC 13765
No fault code found.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0760
2 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Shop #: WSC 13765
6 Faults Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
28-10 - Short to Plus - Intermittent
00975 - Heated Rear Window (Z1)
01309 - Power Steering Control Module (J500)
49-10 - No Communications - Intermittent
00906 - Horn (H1)
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 01
Coding: 12338
Shop #: WSC 13765
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y2 919 880 D
Component: KOMBIINSTRUMENT VDO V09
Coding: 16441
Shop #: WSC 26008
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 13765
2 Faults Found:
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 G
Component: Lenkhilfe 0004
Coding: 00110
Shop #: WSC 00000
1 Fault Found:
37-00 - Faulty
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 C
Component: 0F Komfortgerát 0003
Coding: 00067
Shop #: WSC 13765
Part No: 6Q2959802
Component: 0F Tõrsteuer.FS TFK 0002
Part No: 6Q2959801
Component: 0F Tõrsteuer.BF TFK 0002
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
End ---------------------------------------------------------------------
He cleared the faults but two codes that stuck were the code for power steering, and for 00818 - Sensor for Evaporator Outlet Temperature (G263) .
Do you guys know if this could be the sensor, or the pump? If i was to check the wiring, whats the best way to get to all the connections for the PAS?
Many thanks :D
Yeah it mentions check sensor, but its not really explicit as it leaves it open to being the pump...
Anyone else?
I was thinking, there is a listing on ebay for LHD sensors, I could add a length of wireinbetween to make it long enough to run to the RHS of the car - anyone else done this~?
EDIT:
Also, where would i get a pump from, main dealer is around 130 apparantly, so is there a patent part suppler? What part number woud I be looking for?
Edited by nick dunkley
Anyone else?
EDIT:
Ok so I read at various sources that if you unplug the angle sensor, the power steering goes to default backup mode and will run at least to a certain degree..
I did this and nothing happened, so can I presume that the pump is dead?
The sensor thats in the steering colum is the metal type (updated..) so that maybe suggests its already been changed? and that the pump is the cause?
Many thanks.. Nick
