Oil Service
Hi ppl,
I need to change the oil in my fabia vrs and am unsure as to what to use?
Thread on here says 5w40 to vag spec but if u go on opie oils website and put all the info in they come up with 5w30 vag spec oil?
Any help as to what i need would be great as i know irs very important to use the right oil.
Oh and its a 53 plate.
the most important thing is that its a minimum of PD spec, which is 505.01
some of the new specs supercede this, such as 507/504 which you can use instead, though these are usually more expensive
Fully synthetic 5w40 to VW 505.1 spec. Doesn't matter what brand, I use 'Halfords' £36. 00 for 5litres in POOL, near Camborne.
Good luck.
Hi ppl,
thats strange, i bought an oil service pack from them not a month ago, and it came with 5-40 as I expected.
The product chooser definately goes to 5-30 though. Strange.
As above, ensure it meets the Vag 505.01
PL
Have had an email back from Opie Oils
"505.01 can be 5w-30 or 5w-40, it is also replaced with the more up to date 507.00 which is a 5w-30
Guy"
so that should clear that up!
PL
