AAARRRRGGHHHH - Fabia vRS Power Steering
Hi there
My power steering has just stopped working and the light is up on the dash. I have checked with VAG COM and the error is displayed below. I have also checked the terminations on the pump and all the fuses and they all appear ok.
Code:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6Q1 937 049 D
Component and/or Version: 0000 BN-SG. 1S34
Software Coding: 25738
Work Shop Code: WSC 13765
1 Fault Found:
01309 - Power Steering Control Module (J500)
49-00 - No Communications
Any help would be fantastic.
Cheers DC
Lack of comms probably means the unit is dead, rather than a broken wire. However, I woudl check all wiring and the plug on the PAS pump, just to check. Not sure if there is a separate ABS/brakes module not on the pump.
Cheers for the help, I think your right it's the pump thats gone, got the car booked in today at the garage, so will probably be a few quid lighter after it.
Cheers for the help
DC
How old is the car? The pump is expensive as hell new, so would consider looking at recon units or items from breakers on Ebay. :)
