Temperature gauge
Is there any reason why the temperature gauge should go straight to 90 degrees after only running the engine for about a minute from cold,but it doesn't over heat.any advise welcome
Edited by Dirk Diggler73
usually the temprature sensor mate(green one) not expensive..
As above only £7 when I bought mine 2 years ago. Green is the latest version.
Easy to remove and fit to, just place a cloth underneath to catch the small amount of coolant that escapes and ensure you do it on a cold morning engine.
It gets a film of coolant on it over time, a clean could do the trick, but as its a cheap part, just replace.
Edited by mluton
Nice one thanks lads :thumbup:
