Diesel Power sport 4
Hi all, I'm thinking of getting a bottle of fuel additive such as this http://cgi.ebay.co.uk/Millers-Diesel-Power-Sport-4-500ml_W0QQitemZ270371918259QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef36c11b3 to put in my vRS as it has done quite a few miles (130k) and I thought the injectors etc could maybe use a clean (?)
I was just wondering if anyone knew weather it was unsafe to use in the PD130 engines for any reason? Anyone had and good/bad experiences with fuel additives?
Some interesting info : http://www.seatcupra.net/forums/showpost.php?p=2074321
*edit*
Looks like those tests were done on "VW 1.9TDI" so I guess it is safe :D
I'll let you know the results! ;)
Edited by Thirdtimeluck
Wont do any harm as an injector cleaner, but the Forte stuff is much better.
Forte eh? :o
Thx for the info, ill look into that :)
What makes you say its better? better name?
Using this in my car at the moment and havnt had any problems :)
*edit*
Sign yourself up for the Group Buy on Millers EcoMax (DSP 4 in a new bottle). Link to it in my signature :thumbup:
FWIW, I use Millers because I fill up at the supermarket, so the diesel doesn't have the cleaning additives that 'branded' diesels have. Works out a little cheaper that way, but if it wasn't for the loyalty points, I'd probably get branded fuel and not bother with the Millers...
HTH
Ordered a bottle of this: http://www.forteuk.co.uk/product.php yesterday so might give the group buy a miss this time...
Probably wont bother with any other fuel additives for a while (5,000 miles maybe) as I run this car only on V-power Diesel :thumbup:
But thanks for the heads up. :thumbup:
HTH
Fair enough :)
I haven't had this car long so don't know what its been run on but I plan on "giving it the best" from now on :)
New front shocks and oil change in the pipe-line :thumbup:
I had my Fabia VRS in my local indie garage for its service and MOT and they recommended Forte which I included in the service. They have all the VAG kit and service all their Skoda taxis and use it so it can't be bad!
Roger that!
Nice one :):thumbup:
Roger that!
Forte went in today with just over 1/2 a tank of diesel... bottle says "UP TO 100 liters" so hope it will be ok at the concentration I have used it at.
I can't imagine it would do any harm :no: ... could it? :o :S
*edit*
I;d personally only use Morris lubricants morendo cleaner. It is approved for use in PD engines. Excellent concentration ratio as 125ml does a full tank. I'm still using the same bottle i bought 12 months ago direct from morris.
I've been using it for the last year with no issues.
Edited by newskoda
I've been using millers sport 4 in both our vRS's for a few years now..... The few times i've run out and had to have a couple of tanks of untreated fuel in i've noticed a slight difference in performance and roughness of running.
I have a dragon box fitted and get between 500-550 miles per tank using millers sport 4.
Also isn't the '4' in millers sport 4 to do with the euro 4 emissions standard that the PD130 engine is specced to???
Dave.
Edited by WaveyDavey
