How to fit a Cupra PD160 airbox inlet pipe new Article
Excellent article chavy. :thumbup:
Do you know if the same operation is possible in the Octy range, i.e. 1.8vRS inlet pipe into a 110bhp TDI?
Also, very good photos, beats Haynes any day.
JD
:thumbup:
Good write up chavy!
Faqtastic!
:rolleyes: for the pun, :thumbup: for da man :D
Cheers guys.
CMCM not sure mate, I only found this mod out as it was talked about alot.
CMCM might be worth having a look on cupranet, see if anyone on there might know, they are a nice bunch of lads and lasses (being pc there). Failing that have a look under your bonnet and then under the model in question i.e. Octi diesel 1.9tdi have a look at the cupra leon and so fourth. Just an idea so dont blame with if it doesn't pan out lol
Cheers Mike, will do that.
JD
Good Howto Ivan' date=' :thumbup:
Did you throw away the old inlet pipe and front trumpet or will you sell em for spares?
Ian[/quote']
Nope still got em, if you are thinking what I am thinking what car do you have as these might not fit ? I can measure up the pipe etc if you want.
I've got a Fabia 1.4 16V - mine broke quite badly when I was working on the nearside headlamp and is in danger of falling apart completely! The front trumpet and first part of the pipe that is not my headlamp. :o
If you can get a measurement of the diameter of the pipe I will have a look at the one I have and I will get back to you with it's measurement.
Thanks I will get back to you at the earliest opportunity.
Actually probably best to PM me !
Just contacted Seat, just come into stock.
Will see how it goes!
Charlo
Ordered my pipe's today from Seat and was told i can collect them tomorrow morning, i think ill call them first before i trapse to edinburgh tho.
Hmmm. If I wasn't so busy up in N.Wales this weekend, I'd have been tempted to get these bits... I think a phone call tomorrow is in order. :D
Very nice quide, nice and simple and nice clear pictures, Well done and thank you
On another note though, what performance gains have you seen from using this and a filter? is it worth the 80 quid ish total cost?
no I mean around 80 quid once you have bought a green air filter as well. Sorry should have worded the message better
I think just the fact your engine can breathe that little bit more extra is worth
Phew... :D I already have the green filter corner covered. ;)
Where did you get
Have to agree. Apart from a slightly gruffer induction noise, I can't detect any change in performance on my (standard) vRS. Unless you've been remapped,[/b'] I'd recommend keeping the 30 quid in your pocket rather than the SEAT dealer's.
;):D
