Warning lights?
What does the ABS & the ASR light on the dash mean if they dont go off within a few seconds of starting the car?
Edited by Polo6n1600i
I take it you mean other than if the OFF button on the centre consul has not been pushed??
National
yeah - I mean other than that!
When i get in the car and out the key in the ignition to start the car the heater plugs light goes off, I start the engine and the ABS & ASR light stays on.
I would suspect that it would indicate a fault with the wheel sensors that control both the ABS and ASR. I would have thought that the manual ought to have more information.
If I turn the car off wait a few seconds then turn it back on again the lights go off!
It means a trip to the dealer to get the fault codes read :thumbup:
If the car otherwise works, you could always take the bulbs out :giggle:
Hummmmm, you`ll prob not know something isnt working correctly till you need to to avoid a crash tho.
Matt
ABS sensor? Hard to change??
Ok - been to a mates garage that has VAGCOM to read the codes - says its in intermitant ABS controller fault?? He says they are about £1000 from the main dealer???????????????????????????
