My ESP is on all the time fabia vrs ?
Hello can somebody help me fix it , my ESP is switch on and i cant turn it off iv had the radio out and removed the switch all looks ok :'(
Hello,
I'm afraid that will be a fault with the system., You need someone with VCDS or similar to scan it for you.
Where abouts are you in the country?
T
Incidentally, I assume you mean that the light is on all the time. This means that the system is DISABLED. Normal operation is for the light to extinguish shortly after the engine is started, indicating that the system is operating normally.
"On" all the time!? Do you mean that the telltale and idiot light are always on? Because that means you have a traction control or ABS fault. As said you need it scanning; check the VAGCOM forum to find someone near you who'll help.
Thanks i will let somebody put a scanning kit on it B)
YES its staying on all the time and the ABS light is on sometimes :S
Fault, probably in one of the wheel sensors, but VCDS is still the easiest way of determining which one.
