Colours / Fuel Economy / Sunroof / Towing!
It seems to me the simple solution is a lower hook/ball component from Westfalia. At the same time, they could add the required connection to the break-away wire that is also required by Law, but not provided by the hitch.
I thought so too, a simple soulution
I have talked to Monoflex in Sweden.(http://www.monoflex.nu/en/start)
They have been in contact with Westfalia.
Westfalia says they can not provide a lower towbar.
The dimensions of the towbar is according Skoda guidelines.
When a towbar is built and approved it can´t be changed without new approval. emoticon-0101-sadsmile.gif
Edited by Helgestahill
My Westfalia detachable has a connection for the breakaway wire on left hand side of "receiver" when viewed from rear.(UK spec ?). Still however waiting for the panel to cover the cut- out. GB
Make sure your dealer also orders the inside section of the cut out panel, I have to show my dealer this on their parts screen, because they didn't look properly.
It will be in the dealer for 1 day, since the panel inside section is held on with glue, and needs to 'cure'
Also my Wesfalia towbar doesn't have a hole for the breakaway wire, where is yours ?
a317079691101-317077.pdf
My loop is on left hand side.
Thanks for info on panel fitting.
Edited by geordiebroon
The Pacific blue is nice - thanks for the picture.
Hit on a new issue though - the roof rails on the yeti would only clear my garage door by just over a cm! Would need to take the aerial off! Beginning to think i'd be better going for a facelifted vRS and keeping some money in my pocket! We'll see.
There is a picture about of a Dutch Yeti with a small arial
Dealer mentioned a shorter aerial is available - to be honest I never listen to the radio so would maybe just remove it.
Will need to see if the dealer will lend me a Yeti to try in the garage though as it is going to be tight for height.
