Fuse Box
Hi
Where is the fuse box for a 1.4 Fabia as it's not stated in the manual.
Open the driver's side door - the panel at the 'side' of the dashboard (which would be butted up against the door) covers the fusebox...
Something else to look out for is I think the diagram of the fuses on the fuse box cover is back-to-front? :)
Chris
If you look very closely when you remove the fuse box cover you will see tiny numbers in the plastic by each fuse. The numbers correspond with the numbers in the handbook. Because of my advancing years I had to use a magnifying glass and bright light to make them out! There is also a small plastic tool slotted into the fuse box for removing and replacing the fuses. Make sure when you put the cover back that everything lines up correctly before you thump it into place. The small metal clips can go into orbit and never be seen again.
