After market parking sensore
I have found that reversing in the new Skoda II is quite difficult due to the shape of the hatch.
Is there a recommended kit that woud be suitable... I dont really want to pay dealer prices.
I was looking at a set from Maplin http://www.maplin.co.uk/Module.aspx?ModuleNo=265097 only £20 :p
Also seen one that does not require any hole cutting £79
http://www.parkingdynamics.co.uk/Universal-Sensors/Parking-Dynamics-PD1/Parking-Dynamics-PD1-Parking-Sensor
And another none hole one £49
http://www.parkingsensors.co.uk/eps200.asp
Edited by Andyp
I have fitted the Parking Dynamics PD1 kit to SWMBO's Golf as i liked the idea of not having to colour code the sensors (metallic paint is not recommended by some manufacturers) and TBH i wish i hadn't bothered and just fitted a decent (Cobra etc) kit, as it is fine when it's dry but there are numerous false alarms when the bumper is wet. :thumbdown:
Edit
If you do go for one that requires holes drilling then make sure you buy a kit that uses std sized sensors - so IF the kit packs in you can replace the lot easily with another kit. Ideally fit a genuine VAG kit that uses the flush sensors as they look MUCH neater IMO.
Edited by Gizmo68
Ok.. thanks
