"Lost" Memory II
I've just noticed I've "lost" memory 2. It's just disapeared! I've tried resetting trip etc but I only seem to be able to flick between Memory 1 and normal on the maxidot.
Am I missing something here?!!
Memory 1 and normal? What do you mean?
I do not have maxi dot but if you press and hold the button on the stalk that might work.
OK, Memory 1 and ........... thats it! Looks as if the option Memory 2 has just gone!
On mine you change between memory 1 and memory 2, there's isn't a "normal" Or am I being thick here and missing the point?
I'm sorry I can't resist ....
"Where were you when you had it last?"
Aaahh that's better ....
I assume by "normal" you mean "current" data, such as temperature or instantaneous fuel consumption,
as opposed to the "calculated" averages and totals.
Possibly a loose connection to the button on the underneath of the stalk,
preventing it swapping between memory 1 & 2.
OK OK you lot!!!
Its Memory II thats gone for a walk. Can't get it back anywhere........
Serves you right for having maxidot :S
Have you tried an ad in the lost and found section of your local rag yet ?
Sorry I can't be more helpful :doh:
