driver side front wheel leans in at the top
I have a 1.4 mpi and the driver side front wheel leans in at the top my brother the so call mot man said i have bent my chassie but i have not hit anything just of pot hole but not that bad but i have new tyres fitted to day cause the front drivers tyre has wore more on the inside off the tyre so when they was fittin the new tyre i had a look i have have found my anti rol bar has move to the shock and it been rubbin on the shock could this be the problem cause there is no way i have bent my chassie but my brother the mot inspector never see the anti roll bar hittin the shock could anyone give me a idea if it the anti roll bar causein the problem i will get a pic and up load it asap
Wow, Well, I think I got that all :)
Most likley you either have worn/damaged bushes and/or knocked your camber and alignment out.
Best get someone, other than your brother ;) to give it a full alignment check at a decent garage.
How do I fix it if the camber out mate
Its not something you can really do by eye, the adjustments you make are fractions, itll be part of the alignment service, for a 4 wheel alignment its usually around £60, quickfit/ATS etc will do it for around £25 I think but I reccomend taking it to a speciallist.
cheers mate am goin to be sortin the antiroll bar out on sunday casue it moved over then i will take it to a speciallist
i just love this site you allways get good help and advise from decent people
thanks again
thanks again
Your antiroll bar moved over? Sounds interesting :) If you've managed to bend/move/whatever the antiroll bar that may also account for the wierd camber on your wheel.
thats wot i said to my brother the mot inspector no thats not it bear inm ind he never see it when he mot it but the best bit you cant miss it but i will havein a look on sunday i will post my findings
how did i post pics ppl
