Harddrive nearly full?
It seems my hard drive is nearly full and i really don't know how.Is there any software i can download to tell me where the space has gone?
Just a free simple program will be great.
Check out treesize free
This will give you an overview on where most of the data is stored
What are you running - XP, Vista, 7?
Are offline files turned on?
Have you got system restore enabled?
What size is the disk?
If you right click on C: and properties > disk cleanup > choose what you want to keep and get rid of (untick compress files) > then go to more options > Clean Up on system Restore > Wait a few mins > Click on OK.
This should free up GB's if you are on Vista or 7.
A good tool to download is ccleaner which will clean up all temp files etc.
Just deleted around 30gb from Lenovo rescue & recovery back up.
Running Vista with 120gb HD (106GB) 67 GB Used now
I will do a disk cleanup,defrag
(untick compress files) Should this be ticked? as it isn't in general use?
I do have CCleaner and use it monthly.
Edited by jaymd
Cheers Will try this.
There's no point in using back-up/recovery software (or even having it installed) unless you have a separate device to back-up to. If the disc fails, or catches a virus, you've lost whatever's on it whether you've got one copy or 2.
Can tick it if you want but takes an age and slows down disk access. I bet it is the sys restore files causing it. Defraggler for defraging the drive as vista one is rubbish!
Yeah; check how many system restore points Windoze has created, and get rid of all but the last 2 or 3.
+1 for disk cleanup and a defrag.
Use what you have before spending money.
If you have lots of pictures/vids you might want to consider an external harddrive but remember to backup.
you can also delete all the contents of c:\windows\software distribution\downloads, just the contents and not the folder itself. also check c:\windows\temp and delete everything.
