Tyre wear on Scout and drive bias
Help needed.
I have had 2 sets of new tyres (Dunlop SP1) fitted to my Scout.
The rears have only done 14000 miles each time with the fronts being a little better.
Is this normal?
Second point- I would have thought the intelligent 4x4 system would give a bias to front wheel drive yet my tyre wear seems to contradict this.
Would really appreciate some advice.
20,000 on my rears and still life left in them - have you have the tracking etc checked?
22,000 on both fronts and rears with 2 -3 mm left when I changed mine...
About 20,000 miles and no problems at all with Dunlop SP1's.
I always keep my tires on max allowed pressure and check the pressure at least monthly.
I changed mine at 32,000 miles... All pretty even.
Many thanks Guys.
Very helpful. I have had the tracking checked and all is OK. The wear seems even on each tyre so not sure where to go from here but I will try another set as grip wise they seem very good.
Best Regards
Glyn
Have had Kuhmo Ecsta fitted to mine now. Will see how they go, £91 a corner fitted which didn't seem bad, plus they're quieter than the Dunlops.
What pressure are you running with?
2.2 front and rear.
Mine came with 2.5 both ends, thought i have a heavy net weight 1,645 kg.
I use 2.5 front and 3.0 rear. Better road performance, fuel saving and longer lifetime for my tires :thumbup:
