Coilover Problems!
dont let all this talk put you off mate, i only have very slight knocking noises and im not even convinced its the coilovers, im going to check wishbones/engine mount etc , emoticon-0148-yes.gif
  • Replies 169
  • Views 17k
Thanks :) I have time to weigh it all up and see how, or if, this progresses. I'm hoping that some kind person will give me a spin in an AP or Weitec equipped car before I make up my mind too.
Still awaiting the cure, due in the workshop in a week or two...
Thanks emoticon-0100-smile.gif I have time to weigh it all up and see how, or if, this progresses. I'm hoping that some kind person will give me a spin in an AP or Weitec equipped car before I make up my mind too.
if you were closer than several hundred miles you coulda jumped aboard mate no worries emoticon-0136-giggle.gif ....emoticon-0148-yes.gif
Wee update - going in Friday after lunch to get the springs sorted, hopefully this sorts the noise, if not i'm leaving it there lol :)
Problem solved - looks like all the springs need is a hard rubber tubing to stop the coils touching on bumps and uneven roads, noise is 99% better.
Been told to keep an eye on it for two weeks then report back! :D
Will keep this updated with info as and when I have some!
Been told to keep an eye on it for two weeks then report back! emoticon-0102-bigsmile.gif
Haha thanks! :giggle: Och well I'm going back to Glasgow for college at the end of the month, I'm sure there'll be some kind soul in the area...
Glad to hear a possible solution has been found! :thumbup:
Score!!
They will not admit to a fault with the setup directly............... but my spring covers are in the post :thumbup: (no charge to me)
Shall we check back in about 6 months time to see who has ordered a set and if they are included!
Score!!
They will not admit to a fault with the setup directly............... but my spring covers are in the post emoticon-0148-yes.gif (no charge to me)
tell me more please mate! where from etc? i might try and locate some myself... emoticon-0148-yes.gif
p.s - are they the same as ad-lav is using?
cheers mark
Edited by MarkMac
i expect so, direct from KW, contacted my supplyer of the kit, he spoke to KW, they are posting them out soon.
All bacuse i had mentioned about Ad Lav's result with G-Werks
Ta, so what am i asking for anyways? ie do they have a name or am i calling them 'rubber bits that go betwean the coils' emoticon-0136-giggle.gif
Contact your suppler, tell him to contact KW, explain the problem and if they are in warranty .......... (that is if you have from the KW range)
sorted!! yes mate weitec's, just rang damian @ dp and he's going to sort me some out , also direct from kw emoticon-0148-yes.gif
Edited by MarkMac
that guy is a legend! :thumbup:
And it turned up....... its a bit of plastic hose! :smirk:
hmm i might order a set of ap's then
Any joy with suspension problems in the past - ie similar to ours?
it was the top mounts :doh:
Kw v1
No problems
Well mine seem fine with the fix :)
Been a few weeks now and no knocking noises... :D
