Cigarette lighter not working
My sat nav doesnt have a mains charger so need my cigarette lighter to be working and its not! Any ideas guys?ideally need it for tomorrow too!
Have you checked the fuse? :)
Silly question, where is the fuse box on the fabia?
open the driver door then its where the door meets car, you see a little hole you shove a screw driver in to get the panel out :)
Not a silly question at all :)
Its behind the plastic panel to the right of the steering wheel - facing the same way/angle as the drivers door. Here is a guide to which fuse is for what : http://www.fabia-vrs.com/technical-info/fuse-panel-layout/
No. 42 fuse is the one you want (15 AMP) :)
Edited by Thirdtimeluck
This happened to my Octavia recently and the fuse box on that is in same position!! Just remember that the diagram in the handbook is back to front as is laid out for a left hand drive car!!
Grahane
Grahane
Just print of one of these : http://www.fabia-vrs.com/technical-info/fuse-panel-layout/
Problem solved. :thumbup:
Are you sure it's the ciggie lighter and not the sat nav fuse? I had this and thought the socket fuse had gone but it was the little fork fuse in the charger had come loose. Have you tested anything else in the socket?
Sorry if this all sounds obvious :S
cheers for all the help guys. Popped up to halfords for a new fuse and sorted! Thanks again!
Welcome :) glad its fixed :):thumbup:
