Turbo shaft play
Just got a turbo off an ASZ fabia as a spare, but I've noticed theres a bit of shaft play, probably less than a mm in/out and a little side to side too. Not sure if its tolerable as the bearings don't have oil in or is this a sign that its bad? Its apparently off a car thats done 15k
Any help appreciated :)
Edited by Confused_Cheese
Seeing as the turbo is dry of oil, there will be a little play, As far as i have always been led to believe though , In & out (Push Pull) play is far more detrimental than the Up & down play as the shaft & turbine will naturally centre under load / spin .... As long as you cannot get the turbine blades to fowl the casing......
I recently repalced a turbo on a Subaru Impreza & that had up & down play (30K Miles) but no in & out, I know they are a slightly different beast having no variable vanes but the bearing type is the same Etc. The Old one that came out sounded like casper the Ghost on spool up WoOOooHooo & had quite a lot of play in the shaft in all directions, The 30k replacement had no haunting sounds .. :D
Dean
Edited by dfullb
Thanks for the reply mate. Think i'll call my local trusted garage to see if they mind taking a look for me, probably be able to tell a lot better than i can.
Would it being void of oil also cause in out movement or just side to side/up & down? The blades seem to just very lightly graze the housing when pushing slightly though :|
Definately increased play side to side with no oil .. Plus it is going to expand when hot so tolerances will lessen then ...... As for the in & out (Push / Pull) as you say , get a 2nd opinion or hopefully somebdy with one to hand can check theirs also, Devonutopia (Jason) normally has lots of spares hanging around :D
Dean
Edited by dfullb
Cheers for the help matey :) will see if I can get someone to look at it. hoping its okay but feeling doubtful now
1mm is OK. Even the shaft on my brand new turbo moved a little tiny bit. I guess they can't be 100% rigid?
