VRS Tdi PD running issues
Certainly worth bearing in mind. So, possibilities...
N75
VNT mech - though this does seem to move smoothly when I've manually tested it
MAP sensor
MAF
  • 1 year later...
HI, did you find out what the problem was? I have a superb 2009 TDI that is doing similar, turbo replaced and leaking injectors changed but still has a problem!!
I got shark performance to remap mine and remove the DPF. Since then I've had no problems. I believe primative remaps a big cause of the stutter problems.
Correct. Shark PD170 maps are spot on.
I got my mines remapped by DNA (EJM) in Alcester last summer, but I had the stuttering before I had a remap.
I notice problem more around 1500-2000rpm and in 2nd gear and 3 rd gear.
Edited by Awesam
Try Shark then mate, they are getting a name for tuning these engines well.
