Service items
Ok guys, I'm going to be servicing the Octy today and just need a little help with my shopping list!
Oil - 5w40, right? How many litres do I need to do a complete change on the 1.8t? Does the sump plug need changing each time?
Plugs - Any recommended higher than others? Any I need to avoid?
Oil filter and fuel filter - usual spurious parts ok to use?
Brake fluid - flushing out completely and replacing with Dot5.1 - again how much does the vRS need for a complete change?
Air filter - already sorted
Belt - done last service 12k ago
Brakes replaced last night
Anything else that needs attention while servicing?
Cheers guys and gals
Craig
Craig
You may be best getting a sump plug. Got all my stuff from Skoda it didn't cost much more than anywhere else oil only
Cost jus over £20
Careful bleeding the brakes, you need a pressure bleeder so you don't kill the master clyinder
:+1:
Might as well add pollen filter to that list, they replace that at every service and from Skoda it's not too expensive, something like £6 or £7.
Worth checking the wiper blades as well. And clean out the throttle body if it hasn't been done before.
I always use genuine VAG oil filter and sump plug for an oil change which are about £7 or £8 from the local dealer. You need 5 litres of oil, 4.5 to fill it up and another half a litre for top-ups until the next change. I got 5 litres of Castrol Edge from Opie Oils (They're site sponsors so you get a Briskoda discount) last time I did mine.
If you're using 5.1 brake fluid rather than 4.0 it's good for performance but you do need to change it regularly (like every 6 months instead of every couple of years) otherwise it absorbs air and loses it's performance. I've got a feeling I bought 3 one litre bottles last time I did a change but didn't use anywhere near that much, we'd only got through about one and a half bottles by the time it was bleeding through all the nipples without any dirt in it.
Edited by chicken_eyebrow
As I needed to service my TDI I phoned around for a few prices:
Fuel filter
Dealer: £24.09inc
PartCo: £15.64inc
Eurocarparts: £6.98inc
Pollen filter
All around £10
Air filter
Dealer: £15.98inc
PartCo: £9.50inc
Eurocarparts: £8.14inc
Oil filter
Dealer: £6.52inc
PartCo: £4.04inc
Eurocarparts: £2.75inc
PartCo sell UniPart stuff, based on the Granby Trading Estate in Weymouth
Dealer = Loders Skoda, Dorchester
if you want genuine VAG parts at prices similar to eurocarparts try Sere Motors in N Ireland.
Ask for David Hawthorne in parts and he'll see you right.
Fuel filter
Dealer: £24.09inc
PartCo: £15.64inc
Pollen filter
All around £10
Air filter
Dealer: £15.98inc
PartCo: £9.50inc
Oil filter
Dealer: £6.52inc
PartCo: £4.04inc
I have just got the following from Opie Oils to serivce my TDI:
Air, pollen and oil filter + 5 litres of Fuchs supersyn oil, came to just over £45 including the postage with various discounts.
Sump plug came to about £1.99 from GSF- I bought several a while back to make life easier.
Off to collect 2 litres of G060 tomorrow to change the transmission fluid - £11.60 from TPS.
Wow... that sounds like a good price on the oil, even without the filters.... Sounds like a missed out on a good deal at Opie Oils :'(
I only paid £35 for oil, oil filter, pollen filter and sump plug and that was from skoda. Opie oils are cheapish for brand name stuff but think the oil only came tn £19.50 +vat
Edited by Raf_75
I am using longlife oil for my TDI though, so that will bump up the price, plus a diesel filter costs a lot more than the petrol counterpart.
True longlife does cost abit more
