constant beeping after engine start
HI all i have 2000 w reg fabia 1.9tdi 100pd problem is when i start the engine i get a constant beeping noise which only goes off if i turn engine off and start again which it then goes away,
It does not do it all the time just on occasion any ideas anyone.
this is my latest vagcom
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
TMBNS46Y313157655 SKZ7Z0Y0657222
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00188
Shop #: WSC 13765
3 Faults Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
30-00 - Open or Short to B+
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
00283 - Front Left ABS Wheel Speed Sensor (G47)
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0760
1 Fault Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 09362
Shop #: WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
07-00 - Signal to Low
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Y2 919 880 D
Component: KOMBIINSTRUMENT VDO V08
Coding: 16441
Shop #: WSC 10001
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S30
Coding: 00014
Shop #: WSC 13765
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 F
Component: Lenkhilfe 0003
Coding: 00110
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 A
Component: 0D Komfortgerát 0002
Coding: 00067
Shop #: WSC 13765
1 Fault Found:
00933 - Electric Window Motor: Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
End -------------------------------------------------------
now i already know my abs is doomed three sensors gone i have checked them also and they are open circuit with a meter, i get the 3 beeps on start-up.
this is a separate noise which stays on all the time, also i get the glow plug light flashing all the time but i don't understand what this noise means, could it be expansion tank sensor. i know i need a brake light switch.
Coding: 00002
Shop #: WSC 13765
1 Fault Found:
P0571 - 35-00 - -
Readiness: N/A
Coding: 00188
Shop #: WSC 13765
3 Faults Found:
1 Fault Found:
Coding: 09362
Shop #: WSC 13765
1 Fault Found:
Coding: 16441
Shop #: WSC 10001
Coding: 00014
Shop #: WSC 13765
Coding: 00110
Shop #: WSC 00000
Coding: 00067
Shop #: WSC 13765
1 Fault Found:
Have you tried clearing the faults ? running the car and retesting!
Radiotwo
Could be something simple like a brake light bulb out or brake light switch faulty ;)
