AIRCON
press the aircon button on fan setting 1 and it comes on then goes off ?
any ideas ?
Evapourator temperature sensor behind the dash. let me guess it happens when the engine is warm?
ill check tonight is its when its warm , dont really use it that much i like the window down , :giggle:
any ideas ?
Happens in mine as well but the fan barely pushes anything out on setting 1 for me! Should it be more powerful?
could be the resistor is broken and setting 1 is not working at all?
That sounds expensive... Is it? :(
if it is the fan speed resistor, look at the stick here
http://briskoda.net/forums/topic/170338-how-to-change-fabia-fan-speed-resistor/
part is about £40 new from skoda or the company in the link will repair yours for about £15 i think it was (but you will be without a fan for a few days)
Edited by bluecar1
thanks, I will probably cope without the first speed for now and get it fixed when I can afford it! ;)
looks like a trip to skoda then lol :rofl:
the aircon does not stay on in position 1 , fan works fine !
If it is the EVAP sensor a dealer will want to remove the dashboard to fit a new one but there is a guide on here to do it without touching the mian dashboard. The sensor is about £16 and it took me about 45 minutes to remove the old one and fit the new one.
its under warranty , they can sort it out, :thumbup:
