noise from the front p/s help
hi i have an 05 fabia vrs 91000 miles
it has just developed a terrible noise from p/s front its not all the time
more when turning ? than up and down if ur in p/seat u can feel it through the floor
its not cv joint noise more a cracking sort of noise
i know from these description its hard :smirk: but all help would be great and an ideas
cheers mark
i have changed top mount on strut new
new bottom ball joint
new anti roll bar bushes
new drop link
put new cupra console bushes in a couple of months back
Edited by gfunk
:giggle: any one
:giggle: any one
I had a similar problem on my TDI Octy 130 bhp ASZ engine , a few months back , whenever putting it on full lock for parking etc would get a horrible noise and vibration through steering wheel , was convinced it was power steering pump , it was due a cambelt change , so i asked them to have a look . Was told that the Pulley on the Alternator was the problem . And as they had the tinme belt off pluse waterpump change they could do a Pulley replacement ( they are a seperate item on the octy iwas told and can be replaced without changing the Alternator , and put on a new Aux belt , which i was planning anyway . Parts and labour added £50 to my expected cambelt change . This was with an VW Indy that i have used for the last few services Car is on 120k miles
cheers
but it doesn't come through steering wheel
its more u can here it, it sounds if something is being crunched
i thought steering rack but ok
am baffled
Check steering angle sensor signal, and PAS pump. Also PAS fluid level.
cheers for the ideas have checked level a ok
as the noise is coming from pass side and the power steering pump on the drivers side
would the noise come from that side cheers again mark
cheers for the reply s still have the noise has anyone had trouble with there steering rack or had to replace it
cheers mark
Mine was replaced at around 62,500 miles - the Skoda dealer I broke down near offered a Skoda part or a pattern part at a lot less...
wheel bearings?
I had one give up on my old 54 plate polo, sounds like a grumbling/scraping noise, noise increases when turning, can sometimes feel it feed back through the car to the cabin.
wheel bearings?
it does make that kind of sound
did it do it all the time or some times
and does it not make a wearing sound like a normal wheel bearing
cheers must check it out
thanks mark :thumbup:
