Pierburg 2E-3 Carburettor Overhaul - HELP needed
but I can't get out the hose from brake booster - see image. it looks glued...
Tried warming it gently?
I tried with hot water... and nothing. maybe the all-good WD40 will do the trick  :wonder:
it actualy comes of very easy from the vacuum booster, there is also a middle conector thing that you can separate, or remove the flanger from the manifold.
that happend to me, but after removing the servo itself and servicing it (and noticing there were no leakes) i opte do tune the mix a bit les lean
  • 2 years later...
Hi
I want to replace my pierburg 2e carburettor.What kind of carb do you think I should replace it with.
back in the day the best replacement for a failing 2E2 was a Weber DMTL, so they might do something for the 2e3. Have a look at Webcon and see if there's something suitable in the replacement carb list (PDF). Don't know about availability in SA though.
Hi
What is wrong with your Pierburg 2E3?
Do you have it on a Skoda Felicia/Favorit?
