Stream MP3 and Maxidot
Hi
I recently bought a Stream MP3 from daz_pd to fit to my 55 plate (2006MY) Octavia L&K Estate, to replace the MFD2 that it came with.
I wanted mp3 playback and the PDC and Climate displays on the radio.
After moving the earth connection for the CDC so that it worked, I have a question about what should show on the Maxidot when playing back mp3's from CD. I get all of the song title info on the Stream MP3 display, but all it shows on the Maxidot when I select Audio is CD Track 05 or similar, as if it was playing an audio CD.
I thought with the Stream MP3 you got the song title etc. on the Maxidot as per the display on the Stream MP3? Or am I mistaken?
Not a big issue, just would be nice :)
So, should it work? Do I have a coding issue? (Need to recode anyway to turn off Navigation and also last time I was in there with Mike H we noticed that the coding wasn't done for CD changer, even though I have one fitted and it works!)
Or is it something more expensive like I need a newer Maxidot or a newer CAN Gateway?
Oh, and whilst I am asking questions, I now have the facility to connect an AUX IN on the end 3 pins of the small blue connector in the rear of the radio - can a cable be bought with the necessary pins on that just insert in to the connector so that I can run some screened coax to the glovebox or jumbo box for a 3.5mm jack socket?
Edited by andyvee
never shown on my display and I have stream mp3 and maxidot
At least I know I am not missing something.
Anyone know about the part numbers for an AUX IN connector?
Edited by andyvee
No, only track number and that's it.
Does if you hook it up to the Dension...and you know where I'm coming from...! :giggle:
I do but I can't afford the Dension at the mo Paul :'(
