Octavia VRS Airbag fault codes
Please can any one help me , i bought a light front damage 2002 Octavia VRS and have finally managed to get it all back together ,but the seatbelt light is lit up on the dash it was never lit up when the blown bags were still attached, it seems to have happened since both been replaced, i had a mechanic check the car and he came back to me with the following 5 codes
00595, 00588, 00589, 00532, 01299 i take these codes to be connected to the airbag system can anyone advise what the codes mean, also i notice a circular warning light has lit up on the dash would this be someting to do with tyres or traction control? Any help would be most appreciated.
Have you checked the seatbelt pretensionors?
Is it's a seat belt light or an airbag light?
Hello, sorry it is the airbag light not the seat belt light
Hello, i have checked the pretensioners they are ok
Thought they went off if the airbags went off?? Did you change them??
Edited by Raf_75
01595 Crash Data stored
01588 Air Bag Ignition Circuit
01589 Air Bag Ignition Circuit 1
01299 Daignostic Gateway fault.
0129 Transmission Control Module Low Voltage or Bad Ground.
Did your mechanic try to clear the codes?
Edited by pauldazzle
Hello the mechanic tried to clear the codes but the car would not let him access
The 2 air bag codes could be pointing to a bad connection to the air bag control unit.
Google the fault codes & you should find plenty of info.
Hello, they never went off
Thanks for your help much appreciated
