Drivers controller device
So, seems like my drivers controller device is broken, my mirror electric + heating not working and my electric lock for the door not working.
Now im wondering, where that black thing is? i know its inside of the door panels somewhere.. but i dont know how its looking like.. Someone got a picture from it? or could tell me little bit mor about it..
I try to fix it before im going to buy a new one.. its coting pretty much as a new.
have a search on here, plenty of pictures should appear. It is attach to the bottom of the electric window mechanism. Has a large plug connected into it.
Try this: http://briskoda.net/forums/topic/154117-central-locking-problems/
You will probably have water ingress into the connector block.
The actual CCU is located behind the headlight switch on the dash, I believe.
Before you remove the door panel, you should check for broken wires as they pass from the 'A' pillar to the door. Pay particular attention to the Red/Yellow wire as it may be broken. The control unit for the items you listned is part of the window motor. Although it can be removed from the motor, it is not available separately.
Ty for the replys! seems like all my wiring before the control unit should be fine. Next thing to do is checking the connections of the window motor/control unit.
