Bit of help with turbo upgrade.
Well its safe to say.
Im seriously confused as to which turbo to get!
Someone help me out out here haha.
Is there any other turbo's that fit? garrett gt28's haha :)
non pd130 / pd150's?
  • Replies 70
  • Views 22.8k
  • XLBaconDoubleCheese
    XLBaconDoubleCheese
    You can run any of them turbos with standard setup, just add the `cooler and clutch later. With regards to the turbos, theres loads, i dont understand them all, but "hybrid turbo`s" can be rated anyth
  • Hybrid 130 is the same as a hybrid 150. (If both built to same spec). The only thing that's different is the lettering on the plate on the turbo.
    XLBaconDoubleCheese
    Nope, the car needs to be told that the upgrades are on, which is in basic terms what a remap does. Matt
anything can fit well maybe not anything
i have a hybrid vnt20... requires custom manifold and oil feed....
don't actually know what its off 2.5l tdi / 3.0l tdi
... Thanks jase.
Just adds more to the equation haha.
Uh...
Might opt for unit 18 remap package inc. egr delete, remap and hybrid supply and fit.
But then need to get new clutch etc.
Fun :)
Just scouted about, very similar topic on SCN, found the following;
"PD 130 and 150 turbos have the same size compressor and turbine wheels just different housing, manifold and bolt pattern design."
Matt
the trouble is:
when they are bolted on, both VA and VB look exactly the same...
...if you take the turbo intake pipe off, the diameter of the compressor inlet (=inducer) is bigger in VB.
Same way, turbine outlet or exducer is bigger in VB
:S
I'd just go to Unit18 and drive home with a hybrid turbo fitted and a decent map :thumbup:
Edited by andypandypoos
... Thanks jase.
Uh...
Maybe the torque can be limited to 300lb/ft but around 200 - 220bhp? Then the clutch might last 100k?
yes torque map and bhp map are independant
in my stage 2 fabia it had next to no low down torque (spike-bad)
it was high in the rev range so was clutch friendly
Hmm.
So opting for the pd150 hybrid, map and egr delete from unit 18 sounds good?
Ive been quoted £900 for the hybrid so... :)
Or unit 18 offer a stage 2 150 for 1400...
Might just take the crunch. Get it limited. Then travel back for remap and more tourque etc once funds allow FMIC and clutch.
Expensive time of year :)
yeah, but you can't reduce torque at a given engine speed without also reducing bhp. next to no low down torque means naff all bhp low down :(
why would you want max bhp at 2k rpm anyways?
my stage 2 vrs had no nasty clutch / tire shredding peak low down torque, was gradual until 3k where it just took off was like a disel version of vtec
Edited by BigJase88
:) Sounds like what i want.
and just found a picture when you had the hybrid badge on the back :thumbup:
who said anything about peak power at 2k rpm? I probably do 90% motorway miles, mine's still strong at/from 3k rpm but I don't see the point in fitting a hybrid turbo and then having around SDI power at cruising speeds
  • 2 years later...
i also have a standard vrs and want an upgrade, do i get a remap so its running on about 180bhp then put a pd 150 so it runs better or can i upgrade turbo without remap ?
Upgrade turbo then remap, although you could run a PD150 turbo on standard map.
Wouldn't make any more power though.
  • 5 months later...
turbo dynamics do a stage 2 hybrid turbo with billet wheel 240/260bhp possible
The fire on this one just won't go out... :)
  • 1 year later...
Looking for a turbo code for a hybrid pd150 turbo
Mdx376 or md376
The MDX376 with a billet compressor wheel is a nice turbo. They say to limit the boost to 1.8 - 1.9 Bar but countless people run more than this.
At 2.1 bar of boost you "should" see 230+ bhp with awesome driveability and no breathless feeling you get with the standard tiny OE KKK 130 turbo. And depending on the mapping the torque curve should be nice and linear with no massive DMF/Clutch destroying spikes.
Still smouldering away.....
  • 1 year later...
So if a kkk pd130 is hybridised does that make it a better or stronger unit as I know the kkk models are supposed to be the weak point, or better to go Garrett ?
Consensus is that Honeywell (Garrett) is marginally better made then the Borg Warner (KKK) although I suspect there is a cognitive bias based on the historical aftermarket performance dominance of Garrett in the UK.
In practice you're better off buying a brand new hybrid because most of these units are now 10-15 years old and there have been improvements in quality and therefore reliability.
