Front wipers stopped working
Drove my son to school this morning, cleared the front windscreen of snow and all around the wiper arms. Wiped the windscreen once to clear them of anti-freeze and off I went. When I got back into the car to drive home the front wipers dont work anymore :( Has anyone got a suggestion as to why not? It's -8c, dont know if that has anything to do with it. Back one works fine.
Check the fuse.
http://www.fabia-vrs.com/technical-info/fuse-panel-layout/
I take it you`ve read the sticky at the top?
How on earth did I miss that at the very top?!?
I feel like a bit of a wally now.
Thanks guys, will pop out and get a new fuse ;)
lol, its easy to miss, i skip past all the millions of sticky posts now :rofl: Mine stopped working last winter, i used the interior light fuse for ages cos i was lazy.
matt
Just a quickie to save me looking for the manual or searching on here, where is the fuse panel in the car?
On the side of the dashboard/fascia. You will need to open the drivers door, then you can use your car key (or suitable screwdriver) in the visible slot and prise open the fuse box panel, it should just pop off and pop back on...
Edited by SkodaFabiaOwner
Yeah got the layout from the 1st reply.
Thanks peeps, more invaluble (and time saving) info from fellow Briskodians as always :thumbup:
Sorted the wipers, yep it was just a fuse *sigh of relief*
Tried my washer jets but theyre frozen solid, however I cant hear the pump :(
Could someone help me please? My front wipers suddenly topped working yesterday too. Having googled the problem I went out and bought some fuses and even managed to locate where they are in the car, but when I checked the fuse number (41) given in the manual it seems to be ok. Any ideas?
Can you tell me which fuse needed to be replaced?
Try Fuse 15 (10 Amp)
YES! thankgod changing fuse 15 worked for me, i've been F'ing and blinding all morning after changing fuse 41with no joy! :rofl:
Someone should make a sticky about this... :giggle:
Sorted! Thank you so much. I am a female who is quite independent but when it comes to cars going wrong I panic and usually go straight to a garage - very expensive! But because of this site and your comments not only has it saved me some money I have learnt something too and feel quite good about myself! :)
Mine's the same, wipers working but washer pump silent and no fluid. Did you get yours sorted? I don't think screen wash frozen now. Any ideas?
did you get your washer pump sorted? Mine's not working now.
Get someone to look under the bonnet as you try and use the washer (being stationary will help), looking behind the engine to the passenger side, see if water is spraying out.
Thanks for this.
Just replaced the fuse and wipers and washer working fine. Lets hope the washer bottle doesn't freeze again!
J
