Hello Everybody........I'm new today!
My x reg 82k sdi has developed an engine missfire at a very specific rpm. 1050. Other wise every thing seems ok. If the engine is under light loads eg giong slow in the snow it miss fires at both ecending and decending revs at almost exactly 1050.
I have recently changed the glow plugs to see if that solved the problem but to no avail.
What do you guys think?
I had the same trouble water had got on the ECU and corroded the terminals......this seems to be a common fault but no recall?????
Hi and welcome aboard.
Welcome to Briskoda
Thanks for the info.
What did you do? Clean the connections or replace the ecu?
