rear tyres wearing funny
i bought myself an octy vrs a year ago and it was lowered on 30mm koni springs when i bought it now the tyres are wearing the outter edge off.
anybody got any ideas what could be the problem bushes, shocks ? i havnt a clue
cheers andy
cheers andy
Rear bushes in the swing arm to the axel(hope that's right some will say otherwise if i'm wrong) but def bushes
had a vw mechanic look at it today said the bushes look ok only other think could be a bent axle haha ******* hope not
Maybe well off, but the camber hasnt been adjusted has it?
This is happening to mine a little. Only thing I can think of is goons or MOT perhaps using a jack in the centre of the beam and possibly bending it up slightly causing the rear wheels to push out very slightly at the top.
Just a theory!
Only other option would be to get it to a specialist wheen place who may be able to sort that out (they can shim the wheels/hubs etc)
When i had my vrs on 4 wheel alignment machine at work it said rear wheels run 1.5 degrees camber on rear so if anything they should wear inner edges off
yes the vw mechanic didnt have a clue but the camber would need to be a hell of a way out plus its just the 1 side thats doing it and i dont think there adjustable on the rear either
No nothing is adjustable on rear and you can only adjust tracking on front
