Not a good day...
Lost all boost while accelerating this afternoon, accompanied by plumes of white smoke. Crawled down to the nearest layby and got recovered from there. Recovery guy reckons it's the turbo, but obviously I need all the pipework connections checked over first. No indications at all before this point that things were amiss.
Engine won't fire at the moment, which is another issue as I'll have to work out how to get it down to the garage. Doesn't seem to be battery/alternator related, as electrical systems are functioning OK. So this worries me further.
With the white smoke present I fear the worst. Only error logged is:
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
P0237 - 000 - -
Freeze Frame:
RPM: 2898 /min
Torque: 116.0 Nm
Speed: 102.0 km/h
Load: 100.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Absolute Pres.: 2407.2 mbar
Absolute Pres.: 1275.0 mbar
Readiness: 0 0 0 0 0
Not seen that ever before (and I've suffered a previous Fabia blown turbo). So not none the wiser and Ross-Tech Wiki isn't much help. Think if it were just a blown pipe I'd get a different error log.
Oh joy! Right, off to look at turbo options, in preparation.
Cheers,
Steve
Edited by Wardy
  • Replies 83
  • Views 15.2k
Oh dear, hope it's not a Turbo :thumbdown:
Hope you get it sorted soon.
I'm sorry to read this Steve. If I can be of any help - Do send me a PM.
Thanks guys. Trying not to presume the worst until everything's been checked over, but I've had a few boost pipe issues over the years, and this isn't the same really. Which does worry me!
Fingers crossed hey :)
Cheers,
Steve
Well, I would say that it has to be:
1. MAP (boost) sensor failed.
2. Boost leak
3. Turbo catastrophic fail.
When you say it 'doesn't turn over' do you mean that it won't even crank over on the starter? Did then engine stop dead after the 'incident' or were you able to motor to the layby?
Wardy - what mileage is your car at? (You've got the same model as me hence asking!)
Dougall
That is the usual boost hose fault code though, as that code basically says "Hey, you have a boost leak" (i.e it reads pressure actually lower than requested by the car) and= limp mode. A boost hose is like a huge catapstrophic boost leak.
Fingers crossed! :thumbup:
2. Boost leak
Sorry, bad explanation. Have edited now to hopefully make it clearer. Electrical systems seem OK, hear a click (presumably alternator?) but nothing further.
No, the engine continued to run afterwards. Nearer safe place was about 1/2 mile further on, so I coasted to there. It was on a dual carriageway at the time. Pulled in, turned off and waited for recovery. Engine started once more after this when the recovery arrived and were trying to diagnose the fault.
Just over 81k.
Hi Jason - was pretty sure I had a different one logged on the Fabia. Didn't get loads of white smoke last time though!
Edited by Wardy
Fabia one normally is written out a little differently. I think it says "thrust sensor, negative deviation" - which basically means the same as what you have here, but in better plan English :D
Edit: In fact I think the octy 2 is quite clever in that this could be telling you requested and actual boost being logged?
Absolute Pres.: 2407.2 mbar - this is peak requested boost, about 1.4 bar
Absolute Pres.: 1275.0 mbar - this is "not much" that is actually being read. :D In fact so close to nil I suspect the hose even more
Thanks Jason. Hopefully can get it checked out tomorrow. Still confused with the startup issue though.
And would a simple broken hose/hose clip cause this amount of white smoke? As in, complete invisibility for anyone 2ft behind me??
If its Turbo gone i think it calls for a Trip to Awesome for a Hybrid :thumbup:
Looking at options at the moment.... :smirk:
So is it a Hybrid on the cards then? Followed by a visit to Ben for a Stage 2
Was it the turbo after all?
Should know for sure by the end of the day.
If it is, then yes, likely that I'll go for a uprated and strengthened model, but won't run it at a Stage 2 power levels. Happy with the performance at the moment and would rather have increased reliability by running less boost than a hybrid would ultimately be able to produce. So would get a slightly tweaked STS file from Ben, to largely account for the hybrid boosting slightly later.
Steve
Steve
Good luck <fingers crossed smilie>. Personally I think you need a 3.0 tdi of some sort :)
I think you should lend Steve yours just to see if it will fit in an Octy ;)
I think you should lend Steve yours just to see if it will fit in an Octy emoticon-0105-wink.gif
I hadn't thought that one through properly, had I
I thought you'd need the tractor now it's nearly spring? :p
Sorry to hear of your troubles Wardy-no doubt you'll make the most of it!!! One door never closes but another one opens etc...
I thought you'd need the tractor now it's nearly spring? emoticon-0110-tongueout.gif
Tractor! how very dare you sir!
:rofl:
Pot, kettle, black......
Just jealous really :wub:
Thanks guys!
Will gladly do a straight swap Lady E :D
It's not gonna get looked at today, my usual port of call is snowed under with work.
Cheers,
Steve
Thanks guys!
Cheers,
Steve
You need a 330D Steve and you know you do :D
Now why would I want to go backwards? :p
Less boot space too ;)
Bugger , not fun , gizza bell if you need any help mate
Because going backwards is part of the RWD experience/fun emoticon-0110-tongueout.gifemoticon-0140-rofl.gif
