Eibach Pro springs
A bit gutted after the dealer telling me it would be £300 and 1 day in garage to fit my Eibachs.
Is there any VAGCOM diagnostic issues to worry about if I get a non Skoda guy to do the job....
Have you got the springs as the Skoda option is now deleted.
Yip, the Fun Prevention Officer got me them for Chrimbo...A local garage would fit for £120, but is worried about the diagnostic system.
Can't see what problems they forsee with the diag system????
All they are doing is fitting springs???
As long as they don't turn the ignition on if they have to disconnect ABS sensors in order to fit the front springs (not sure if you need to or not) then I can't see that anything else could cause issues?
Yep, what a load of twaddle! A day in the garage to fit some springs?! Factor in 30 mins a corner.
Where are you? If you put a bit of geo location in your profile, we might be able to suggest somewhere suitable.
Steve
Out of interest Rob what defines the springs as Skoda rather than just Eibach? Is there a marking on the springs or are they just in a Skoda box?
They are marked Eibach and in Eibach Box, no Skoda markings except on box identification panel..They wern't supplied by dealer, they came from supplier
I've just been quoted £370 at the dealer's reduced rate (would be £625 at full rate). Good discount but I make that 5 hours! Should be half that tops I reckon, 30 mins a corner + 30 mins on the alignment machine for someone with a lift and some experience.
I'm sure I read on here that someone got a VW main dealer to do theirs for ~£180.
If someone can recommend a good place near Luton that'd be great. I'd consider doing a DIY job but I'm not 100% confident about dismantling the front suspension. I guess I'd need spring compressors too?
