Strange problem
Well my vrs has developed a strange problem. It's a kind of whistling noise when accelerating.
The usual TDI whistle and whoosh is there but when the car is warmed up and turned off for 30mins or so, when i turn it back on there is a whistle, that is louder than usual when the turbo kicks in. After a while of running the loud whistle just goes back to the normal whistle.
What could this be?
Most likely a slight boost leak, probable at the top connection to the inter-cooler.
Hopefully not your turbo.
Unfortunately mine went a few months ago, and it made a similar noise on boost.
Ali from Unit 18 and Paul from RS Tuning both said it sounded like it was over-boosting, and sure enough when the car was at Shark Performance getting repaired Ben found a boost pipe with a considerable split. If only I'd had it checked out, hindsight eh?
I'd have your car checked for boost leaks, as they might be causing it to over-boost, which may be the noise you're hearing. With the benefit of hindsight, that is what I should have done.
Also, if it develops a police siren type noise, certainly get it looked at as that more than likely will be a turbo problem.
From my experience, it'd be worth having someone who knows their stuff having a good look at it; as a few quid spent on that is way more desirable than dreaded turbo issues.
As I said, hopefully it isn't your turbo and might be something trivial, no doubt someone will post some probable causes soon. Whatever it is, I hope you get it sorted quickly and cheaply.
Did you notice any loss in performance, or black smoke??
Edited by kotlewski69
you sure? Would that no be accompanied by smoke and a loss in power, cos i have neither of those
Not always, I have a boost leak but doesn't smoke any less than usual and power still feels strong.
No smoke or loss of performance at the time. If I were you I'd drive it steady, off boost, and try and have it looked at as soon as you can.
Sorry I can't help any more, better safe than sorry though I'd say.
