HELP! Sat in the garage wie the Octy on stands
Hi after some help here please,
trying to change my rear discs and pads and even with a rewind tool the pistons wont rewind! I'm on my mobile broadband in the garage at the mo, any advice?
Silly question, but have you unscrewed the brake fluid Resevoir cap? Just makes it a bit easier :thumbup:
Edited by sivrs
Hand brake off!! Wd40 under the boot, are you turning the piston the right way( is it sided) and keep pressure on when turning....
hand brake is off, bleed valves open, turning it right and got a pressure plate ................
Should be ok then. It does take a really stif turn to get going sometimes. Especially if the pads have worn very low. Have a stronger go it will turn. (clockwise) to wind in.
Try turning it the opposite way, (I had the same problem on the fabia the other day) and You don't need to open the bleed nipple just a cause of problems
Radiotwo
Edited by RADIOTWO
I believe it is advised that you do use the bleed nipple on the caliper and do not open the reservoir cap. The back flow can cause problems in the ABS or master cylinder (or something) apparently.
Not heard hat one before and done the job many times, however to change rear pads there is no real need to undo any brake lines or unscrew reservoir cap. :thumbup:
The pistons can be really difficult to turn back i had tool with a spanner on end of it to push them back
Old wifes tale
If you think about it,every time you use the pedal, it pushes fluid one way, then when you release it goes back, so no problem, but the amount of times I have heard "I undid the bleed nipple, and now I cannot get a firm pedal (After bleeding) "
I have never undone the nipple for just pad changing etc, only done it if I had to replace a brake hose and then have to re bleed
Radiotwo
