Wheel arches, whats best to clean them?
As per the title realy. Whats best to get all the crud and muck out of the material in the arches?? I allways give them a good soak of snow foam, but it doesn't seem to make much of a differance :dull:
The last thing I want to do is use a product or brush that knackers the material :no: Any suggestions please??
jet wash?
jet wash?
Allready do that (should have made that clear) thats how I apply the snow foam :S
Vikan wheel arch brush?
Link to one of Baker 21's details with him using his :thumbup:
Edited by alexandjen
Thanks. I thought that would be the kind of brush, but I'm worried about the felt type material in the arch. don't realy want to damage it .........
You'll be fine using a brush on fabric arch liners.
I use a circular washing up brush from Sainsburys on all the Maserati arches @ work....does the job just fine & mega cheap should you get overzealous with the scrubbing & the handle snaps :dull:;)
Thanks :thumbup:
Ive always wondered why manufacturers used these as theyre a bitch to clean. I prefer the plastic ones anyday. A soft brush sounds good. Wonder if its something to do with sound insulation?
Exactly this reason. To reduce road roar from the tyres & the noise created by the airflow around the arch generated by the wheels spinning. :thumbup:
All Purpose Cleaner and a brush followed by a pressure wash if you have one
Best with the wheels removed of course
:thumbup:
As stated by Chris, no chance of damaging that material, it's designed to withstand all sorts of grime and stuff hitting it............ :thumbup:
Completely agree on them being a pain to clean, store so much dirt and water but as Chris has said, they are there for a reason................. :p
I'd go with what's been said already. I tend to use a Virosol or Meg's APC solution on them, with a cleaning brush.
Also, in addition to the sound insulation I think the felt-type material also helps to keep road spray down, compared with a simple plastic liner. But the sound issue is the main reason.
Steve
Thanks chaps ;)
