PastyBoy DIY Alloy Refurb and Recolour Project Thread
Best not to think about it, that's my logic :D
  • Replies 135
  • Views 21.9k
  • thealienfromura
    thealienfromura
    Use 400 for the last sand to get all the grooves out. a thick primer should help fill any cracks to custom xbox for the win
  • Hi John Because I stripped mine all the way back to almost bare metal all over I primed the whole lot inside and faces so that the paint had at least somethnig to stick to.   The corrosion on the f
  • In my mind the insides never get seen so why worry to much about the final finish. As long as the corrosion was stopped - which wire brushing and sanding it right back then priming and painting shoul
I know cars is between 20-30 lol
Am going to do my wheels wot filler did u use matey on one off mine wheel I have abit off bubbling tothe alloy
Did you use etch primer at all, or just normal primer??
Am goin to use filler primer
Filler primer and chemical metal to repair any dents etc
There's no dents on mine, so just sanding and filling the corroded areas, then sanding again to get it smooth before spraying but i've only got normal primer for wheels and not etch primer that others suggested earlier in the thread. I'm not planning on respraying the whole wheel, just the areas that need it, so wondered if i needed etch or if the normal primer will do??
I stripped mine right back all over and just used normal primer.
Etch primer just has a bit of acid in it to allow it to bond better with wahtever you spray it on to.
i can't see that you'll have any problems with normal primer if you sand them down adequately
Cheers Cliff. :thumbup:
I'm not planning on a full refurb, so just wanted to make sure.
Lacquer sticks to paint
paint sticks to primer
primer sticks to wheel or etch primer REALLY sticks to wheel
:D Cheers for the dumbed down version of your thread. :D
