Possible to get voice dialling with Columbus plus Bluetooth kit?
Does anyone know if it's possible to get a Bluetooth kit that integrates with a Columbus and includes voice dialling? I know there are Parrot kits that include voice dialling, but they don't integrate with the Columbus.....and the Fiscon Basic Plus integrates really well with the Columbus but doesn't include voice dialling (to my knowlege...?)
Is there a Bluetooth kit out there that will do both?
Or....is it possible to control a Fiscon Basic Plus kit via the Columbus voice control? And if so, would you need two separate mics (one for Columbus, one for Fiscon) or can they both use the same mic?
Thanks :thumbup:
apparently this one does the trick......"VW/Skoda/Seat 9W7 bluetooth kit"
u'll need VCDS to turn it on so the car can see it.
Edited by JR RS
We fit the original Bluetooth kits which give voice control with the Columbus and steering wheel controls if fitted.
How much for a supply and fit off the bluetooth mate?
I have the Columbus unit.
Ahhh steering wheel controls.......if only!!!!!!! :rofl:
Does the original Bluetooth kit require an rSAP phone? I've got a SonyEricsson (and will have for at least the next 9 months or so) which I don't think is rSAP...
Edited by slicendice
That certainly appears to do exactly what I was after...is this the original Skoda/VAG Bluetooth kit?
We supply and fit the original Bluetooth for £399 including VAT :thumbup:
Well we can fit the steering wheel too if you'd like ;)
You don't need an rSAP phone, the modules we fit work in UHV (normal handsfree) mode.
Hot diggety!! Really...?!? Though presumably not a vRS steering wheel with controls??
So a Bluetooth kit that works with normal phones, gives full voice control of Columbus plus voice dialling for £399???
Hmmmmm......!!! B)
You basically fit what you like - something from the VAG stable helps though! Something like....?
No diggety, no doubt! VRS wheel if you like, Mk5 or Mk6 Golf wheel if you fancy?
And yep, that's the deal. To be honest we're doing a lot of them, they are a good seller emoticon-0100-smile.gif
Edited by shark_90
sure is.
a person here has fitted it. quite easy to install i'm told.
plug & play.
even easier with my11 models as they already have the mic in place (if factory fitted with a columbus).
if u don't have the factory installed mic in place, than u'll have to find a nice spot to put it. a mic comes supplied with this kit.
Edited by JR RS
Shark would the Bluetooth work on the mfd2 unit or just the Columbus? Do you also fit the Columbus and how much?
Look at all those buttons....!!! :rofl:
I'm guessing something like this would have a wacking great VW logo on it though...?
It would originally, as it's from a Mk6 GTi ;)
Not sure if there's a suitable airbag unit from Skoda that would fit that particular wheel. But that one was going complete with the original unit for £320, for reference.
Alternatively get a badge made up to stick over the top :thumbup: - Group Buy running currently in fact :yes:
Ben, is the kit you supply the 7P6035730C with A2DP?
