Signal booster - Step by step guide?
Since fitting my Aftermarket HU ( Sony MEX-BT3800U ).... I have had shocking AM Reception...
I have been told i need a Signal Booster. Can i pick one up in Halfrauds and will it come with instructions on what i need to do with it?
Is it as simple as plugging into the back of the stereo and voila? I'm not to savvy with splicing up wires etc :doh:
Please help a numptie out!
Ta
EDIT: Seems to be some confusion on my part....I think i need part PC5-52 which is not a booster, all it does is provides a 12V feed to the antenna, there is an amplifier built into the antenna and that needs a power supply to power it. The PC5-52 routes the 12V to the antenna and ensures the 12V does not enter the radio as that would most likely stop the radio from working.
Edited by Beancounter1980
*Starts watching topic*
Need the same answer.
The blue wire just needs to be attached to the red 12v feed, simple as that.
http://www.caraudiodirect.co.uk/product_info.php?products_id=9861
This just plugs into the back where the aerial goes, but I'm not sure where the blue wire goes
Just ordered one! :thumbup:
:thumbup:
Cheers guys. I currently don't have an Amp in the VRS so i dont know what difference this should make if any. Will give it a bash on the weekend
Thanks Again!
