windscreen problems
hi from kevin i have a skoda fabia 1.4 classic 02 and about a month a go noticed that when it was cold something happened to my car every time i put the key in the ignition and started the car the windscreen wipers switched them selves on for about 8-10 goes then stopped in different places and i had to push the lever down and stop them in the right place - if i the lift the wiper stork up one noth there was nothing - lift it up one more notch perfect and again lift it up another notch for the fast one that worked perfect its just the main timer windscreen does not work - skoda said it was the stork lever was gone and wanted 180.00 pound to replace it - but then one cold day switched it on again and the system worked perfect - in the afternoon it was back to playing up again - after this happened the back wiper suddenly came on and would not go off so a garage that i went to took the fuse out of the fuse box - most days it is the same put the ignition on and the wipers come for about 8 times then pust the stork up once and nothing push the stork lever up again and they stay on and they work on the fast one - if i pull the washer wiper in the water comes out any clues i would be very gratefull not sure how i check any answers you give but will look back thanks all kev
welcome to briskoda
Hi and welcome board.
Welcome to Briskoda, not sure on your query but sure someone will be along to help.
