Worrying beeping noise
got in car tonight, drove off applIed brakes, then a beepin noise started, looked at the dash no symbols displayed then after a bit it stopped. started again, so i stopped Car removed key, started again an everything was fine! has any one got a CLUE wot this cud be? cheers
no it sounded it different, plus when that happens it flashes the temp on the dash! any other idea's??
You may hear a very very faint beeping noise under some heavy breaking, but thats normal... I hope :D
With the octy you get a beep if the handbrake has not been released properly when speed reaches about 5mph. Perhaps the furby is the same.
my furby vrs gives a warning beep if you drive off without releasing the handbrake fully
Yep, mine did that once, and it caused quite a confusion for a minute I can tell you :rofl:
Er, this may seem silly, but have you got an alarm on your watch, or PDA, or mobile phone? Also, I had a tookit in the boot of my car with a metal detector that switched on. It confused me for a while.
Handbrake has a warning light though.
no, i went out last nite applied the handbrake a little and drove above 5mph, n i can confirm that the beep is exactly the same, cheers for everyones help!
Did you skid in anyway while breaking without removing traction control? The car beeps when it's in that situation...then again, even when you remove traction control it does that.
If it was two beeps you could have squashed a roadrunner.Did you see a cayote?
Sorry.Not helpful :o
:rofl::rofl::rofl::rofl:
I did that with a walkie talkie I had still in my work coat. It was beeping all theway home and it was bugging me as I could not trace it. I only realised what it was when it went into termial mode and sounded like someone had died in casulty.
